This is a fly I sometimes find when I go on a walk through the sand dunes. It is small with silvery hairs and called Thereva annulata.
I am trying to find a compromise between resolution and depth of field. I'll included a cropped detail of the same image with the smallest details.
Wim
silvery fly
I have never seen a fly like this before either Wim. I thought we had some strange stuff here in our mountains but nothing like this I would imagine. A great job on the photographs Wim, do these bite?
Wim,
Good compromise! Looks like you might even stop down just a bit more. I'm not seeing fuzziness even in the actual-pixels crop.
What were the parameters for this shot (magnification, f-stop)?
BTW, I notice that this fly uses the "square" layout for its eye facets. Reminds me of Charlie Kreb's post showing this at higher magnification. I wonder why some use square and some use hexagonal?
Thanks friends!
I think it looks a bit like the Abominable snow-fly!
It was done with a 105 mm. sigma macro objective as close as I could get so the 1 to 1 with the smaller than 35mm Nikon sensor. And I used a ring for some extra magnification. The insect is not much begger than a centimeter.
f-stop was 13. I think with 16 I would get slightly less resolution but it would need a big print to see the difference. With some sharpening you can alway make it a bit more crispy when you have stopped down too much:-)
Wim
Wim
